Unable to Connect via Remote Desktop – Need Assistance
VINAYAKA G 0 Reputation points
2025-10-12T03:38:10.1333333+00:00
Hello HP Support,
I have an HP laptop, and Remote Desktop Connection was working earlier but now it shows an error saying it can’t connect to the remote computer.
My laptop is running Windows 10. I haven’t changed any settings, but it stopped working suddenly. Could you please help me fix this issue?
Thank you,
Vinayaka
Windows for home | Windows 10 | Desktop, Start, and personalization | Other
  1. Kimberly Olaño 23,615 Reputation points
    2025-10-12T04:55:34.5633333+00:00
    Hi! VINAYAKA. Thanks for the details. If it was working before and suddenly stopped, you may need to reset the network configuration:
    1. Open Command Prompt as Administrator.
    2. Run these commands one by one:
    • netsh int ip reset
    • netsh winsock reset
    • ipconfig /flushdns
    1. Restart your PC.
    See if this helps. If you need further assistance, just let me know.
    Best regards,
    Kimberly
