Azure Front Door gRPC support
Twan van Beers (NB) 50 Reputation points
2025-10-09T16:23:13.2566667+00:00
We have a tenant that is part of the private preview for gRPC through Azure Front Door, and that works well for our dev/testing, but our MS contact seems to have left.
We'd like to understand the ETA for getting gRPC working with Azure Front Door, as we are nearing a production date and would love to use gRPC through Front Door in Azure instead of having to look for a platform that does allow gRPC through the infrastructure
Azure Front Door
Azure Front Door
An Azure service that provides a cloud content delivery network with threat protection.
2025-10-09T20:24:37.0466667+00:00
Hello @Twan van Beers,
Welcome to Microsoft Q&A Platform. Thank you for reaching out & hope you are doing well.
I understand your question about ETA for getting gRPC working with Azure Front Door.
Currently, Azure Front Door does not support gRPC for backend connections in production. Although it enables HTTP/2 between clients and Front Door, the connection from Front Door to your backend still uses HTTP/1.1. Because gRPC requires HTTP/2 throughout, it cannot be fully supported through Front Door at this time.
Microsoft update: current status
  1. Frontend (client → Front Door): HTTP/2 is functioning correctly.
  2. Backend (Front Door → origin): Currently, only HTTP/1.1 is supported, which prevents gRPC calls from completing successfully.
  3. Microsoft has not provided a timeline or ETA for when full gRPC backend support will be introduced.
  4. If you’re testing in private preview, you may encounter limited functionality, and it is not intended or supported for production workloads.
  5. As of now, there is no public update or roadmap available for when gRPC backend support will be introduced to Azure Front Door.
For more information: https://learn.microsoft.com/en-us/azure/frontdoor/front-door-http2
Kindly let us know if the above helps or you need further assistance on this issue.
Please do not forget to "Accept the answer” and “up-vote it” wherever the information provided helps you, this can be beneficial to other community members__.__ It would be greatly appreciated and helpful to others.
0 additional answers
