An Azure service that provides hosted, universal storage for Azure app configurations.
Issues using login w/ Azure for setting up a Entra app
Ravi Patel
0
Reputation points
Hi there,
We are having issues even just logging into Azure to setup an Entra app for supporting Entra SSO in our application. Below is the error we received. I could not even access the Support feature to send a support request from my Azure account.
"sessionId": "0a2c056f2d8c437d886c1f2803c5de76",
"errors": [
"errorMessage": "interaction_required: AADSTS16000: User account '{EUII Hidden}' from identity provider 'live.com' does not exist in tenant 'Microsoft Services' and cannot access the application 'e6694c91-1590-4e35-9bb7-b865c638b9c1'(Microsoft_Azure_SupportPortalExtension) in that tenant. The account needs to be added as an external user in the tenant first. Sign out and sign in again with a different Azure Active Directory user account. Trace ID: cb81775b-b2e7-424c-99f4-83adcfc22e00 Correlation ID: 8e50a7d7-3dcb-47fd-a478-81a7a6735114 Timestamp: 2025-10-09 14:10:07Z",
"clientId": "e6694c91-1590-4e35-9bb7-b865c638b9c1",
"scopes": [
"959678cf-d004-4c22-82a6-d2ce549a58b8/.default"
Appreciate any support you can provide.
Thanks in advance!
Azure App Configuration
Sign in to answer
