How to retrieve work I saved but accidentally pressed discard
Monique Samuels 0 Reputation points
2025-10-09T01:24:30.67+00:00
I have done some courses work which is needed to be handed in every time i finished doing a part I pressed save and then when i was finally finished i went to save but accidentally pressed discard now i can’t find it and even when i go on version history can I get it back ?
Microsoft 365 and Office | Word | Other | Android
  1. Thomas4-N 21,570 Reputation points Microsoft External Staff Moderator
    2025-10-09T02:31:08.33+00:00
    Hello Monique Samuels, welcome to Microsoft Q&A forum.
    Unfortunately, when you exit Word, the app removes the unsaved changes from memory. This action cannot be undone, and the version history will only show previously saved versions—not the discarded one.
    Now your best chance is if AutoSave was enabled and the file was stored in OneDrive or SharePoint. In that case, open the document online and check its Version History to see if the most recent saved version is available. You can also look in the Recent tab in Word or the Files app on your device to see if a cached copy exists.
    If the file was saved only locally and not synced to the cloud, the discarded changes cannot be recovered. For future work, enabling AutoSave on cloud-stored documents is the best way to prevent this issue.
    Kind regards,
