Keep it short, direct, and specific like how you’d ask a senior engineer on Teams.
DC GERIZON 0 Reputation points
2025-10-06T13:51:17.2266667+00:00
What I'm Trying to Do
Briefly describe your goal — e.g. integrating Azure OpenAI with a web app.
Steps Taken
  1. Created resource in Azure portal
  2. Generated API key
  3. Configured Node.js backend
  4. Tested endpoint received error 401
Problem / Error Message
Error 401: Invalid authentication token
Expected Result
API should return the response payload from the deployed model.
Additional Context
  • Region: East US
  • Model: gpt-4-turbo
  • Subscription type: Pay-As-You-Go
Azure | Azure ISV (Independent Software Vendor) and Startups
  1. Deleted
