GroupMe- Data Export Not Showing in Window
Nathan Swords 0 Reputation points
2025-10-06T13:18:23.5133333+00:00
When creating a data export, it says it is completed, however it is not showing in the screen. It's just a blank space. This is a continual problem starting about 6-8 months ago....It was never an issue before then. I don't know how to remedy this issue and I need the files that I have selected to export. Screenshot 2025-10-06 at 9.17.08 AM
GroupMe | Campus
GroupMe | Campus
A feature within the GroupMe app designed to help college students connect with classmates, discover student groups, and stay informed about campus events.
    2025-10-06T13:52:18.21+00:00
    Hi Nathan,
    It looks like the export process is marking as "Finished," but the actual file isn't appearing in the interface. This seems to be a recurring issue that others have also reported over the past few months.
    You can also try these if it might help you:
    1. Refresh the page or log out and back in to see if the file appears.
    2. Try a different browser or use incognito/private mode to rule out any browser-related issues.
    3. Clear your browser cache and cookies, then check the export page again.
    4. Check your email – sometimes GroupMe sends the export file link directly to your inbox.
    5. Re-initiate the export and wait a few minutes before checking the status again.
    If none of these steps work, I recommend reaching out to GroupMe Support https://support.microsoft.com/en-us/office/how-do-i-contact-groupme-customer-services-906e6ade-807e-46b3-ba6c-510cd01a0647 and including a screenshot of the issue, along with the date and time of the export attempt. Hope this helps.
    Best regards,
    Jeric
