how to insert a webpage into powerpoint
David Bergman 5 Reputation points
2025-10-05T21:10:10.5166667+00:00
I've been trying to figure out how to insert a live webpage within a powerpoint. (Not linking to open in a browser - but staying within powerpoint.) Many of the addons seem to be discontinued.
Thanks for pointers.
  1. Paulo GM 72,650 Reputation points Independent Advisor
    2025-10-06T00:09:16.6333333+00:00
    I agree. It seems the Web Viewer was discontinued because of low usage and failure to meet Microsoft’s internal threshold for continued support. As a workaround, another possible solution is to use Microsoft Sway, which supports embedding content, although this only works with supported platforms. You can check whether the website you’re trying to embed is included in the supported list mentioned in the article. Aside from that, I’m afraid there may not be another option that fits your needs using PowerPoint.
