Azure Function HealthCheck does not inject x-ms-auth-internal-token
2025-10-03T11:24:53.46+00:00
When CORS is set, HealthCheck normally injects x-ms-auth-internal-token into request header.
Due to some needed changes, we removed CORS from the Azure setup and moved this logic into a middleware. This removal of CORS caused HealthCheck to be Degraded due to 401s returned.
Upon logging the request headers I noticed that x-ms-auth-internal-token is not sent when CORS is removed.
Our current solution is to remove this security check from the HealthCheck and make it public.
Is this desired behavior or a bug?
Azure Functions
Azure Functions
An Azure service that provides an event-driven serverless compute platform.
David Broggy 6,801 Reputation points MVP
2025-10-03T12:50:16.8466667+00:00
Hi Milena,
This is desired behavior, not a bug.
  The x-ms-auth-internal-token header is automatically injected by Azure App Service when:
  1. Authentication is enabled on the App Service
  2. The request originates from within the same App Service environment (internal calls)
  3. CORS is configured, which signals to Azure that cross-origin requests should be handled
  When you remove CORS from Azure configuration, the platform no longer recognizes these as internal/trusted requests, so it stops injecting the authentication token.
  Here are some suggested solutions, rather than making the HealthCheck public:
  1. Use IP restriction - Allow health check endpoint from Azure's internal IP ranges
  2. Custom health check endpoint - Create a separate /health-internal endpoint that bypasses auth, restricted to local/internal IPs only
  3. Configure CORS minimally - Re-add CORS with restrictive settings just to re-enable the internal token injection
  4. Use App Service's built-in health check - Configure it in Azure Portal under Monitoring > Health check, which automatically bypasses auth
  5. Anonymous auth for specific path - In your middleware, allow anonymous access only for /health or /healthzpaths
  Recommended approach:
  // In your middleware
  if (context.Request.Path.StartsWithSegments("/health") &&
      context.Connection.LocalIpAddress?.Equals(context.Connection.RemoteIpAddress) == true)
      // Allow health check from localhost/internal
      await next();
  Or use Azure's native health check feature which doesn't require the auth token.
0 additional answers
