Laoptop issue working slow on 1 Millon excel record
Muzammal Ahmad 0 Reputation points
2025-09-30T07:21:07.1666667+00:00
I have an HP i5 7th generation laptop, and I need to work with an Excel file containing almost 1 million records. Currently, it takes around 40 to 50 minutes just to open the file. Could you please recommend what laptop specifications I should go for so that this file opens instantly?
Windows for business | Windows Client for IT Pros | Performance | Application technologies and compatibility
  1. Oliver Nguyen 1,500 Reputation points
    2025-09-30T10:25:24.32+00:00
    Hi Ahmad,
    You should consider checking your RAM as 32 GB is better (16 GB may work but can still be slow)
    Your storage is also an idea to take a look as NVMe SSD (PCIe Gen 4 or Gen 5 preferred). Remember to avoid SATA SSDs and hard drives. Also, the Excel version should be 64-bit as it would use RAM more efficiently.
    If the Answer is helpful, please click "Accept Answer" and upvote it.
