windows 11 : how to fix spacing problem with desktop icons ?
Edgar DOUSI 0 Reputation points
2025-09-29T12:09:41.6966667+00:00
Recently the spacing of my desktop icon has change, without my interaction.
How to reset to normal spacing ?
Windows for business | Windows 365 Business
  1. Oliver Nguyen 1,500 Reputation points
    2025-09-29T12:50:47.6166667+00:00
    Hi Edgar,
    You can edit it with registry:
    1. Press Windows + R and enter regedit to open the Registry Editor. Find HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics.
    2. Find and edit theese values:
    • IconSpacing (horizontal spacing): Set the value to -1125. Click OK to save
    • IconVerticalSpacing (vertical spacing): Set this value also to -1125. Click OK to save
    1. Restart the computer to apply.
    You can also use free tools like "Desktop Icon Spacing" or "DesktopOK" as they can also restore default spacing without editing the registry directly.
    If the Answer is helpful, please click "Accept Answer" and upvote it.
  2. Deleted
