Formula Builder Problem - Excel for Mac
Torin Westfall 0 Reputation points
2025-09-20T20:57:33.3066667+00:00
Whenever I am using the formula builder function in excel for MAC, whenever I try to add something to the row num or column num it adds it to the section before. Does anyone know how to solve this issue?
For instance
When using the formula builder for INDEX
Whenever I am trying to add the row number to the row num it automatically adds it to the array section
Microsoft 365 and Office | Excel | For education | iOS
  1. Ryan-N 15,750 Reputation points Microsoft External Staff Moderator
    2025-09-20T21:58:56.74+00:00
    Hi @Torin Westfall,
    Thank you for contacting us and reporting the issue with using Formula Builder in Excel for Mac, specifically the error where entering values into the row_num or column_num arguments incorrectly inserts them into the array field. We apologize for the inconvenience this issue has caused.
    Below are the steps and alternative methods to help you build formulas correctly:
    1. Manually Fix the Formula After Using Formula Builder
    If you still prefer to use Formula Builder to select the data range and function:
    • After inserting the formula using Formula Builder, check the formula in the formula bar.
    • If you see an incorrect “+” sign in the formula (e.g., =INDEX(A1:A10 + MATCH(...))), replace the “+” with a comma “,” to correctly separate the arguments.
    • Example:
    • =INDEX($A$1:$A$10 + MATCH($X$1,$B$1:$B$10,0), 1)
    • → change to
    • =INDEX($A$1:$A$10, MATCH($X$1,$B$1:$B$10,0), 1)
    • Press Enter to confirm the corrected formula.
    1. Use the Formula Bar to Nest Functions Manually
    You can nest functions using the following method:
    1. Select the outer function (e.g., INDEX) using Formula Builder and fill in the Array argument.
    2. In the Row_num field, type MATCH( but don’t complete it yet.
    3. Click on the MATCH( part in the formula bar to switch context to the MATCH function.
    4. Fill in the arguments for MATCH as usual.
    5. Then click back on the INDEX function name in the formula bar to return.
    6. Click “Done” to complete the formula.
    This method helps Excel correctly interpret the nested function structure without UI errors.
    1. Avoid Using Formula Builder – Type the Formula Directly
    If you're familiar with Excel syntax:
    • Type the formula directly into the cell or formula bar.
    • Excel will assist with auto-completing function names and arguments.
    • You can use the mouse to select cells or ranges while typing the formula.
    I sincerely apologize for the inconvenience this issue has caused you. The issue you're experiencing has been identified as a known bug and is currently under investigation by Microsoft.
    As a moderator, I am not directly involved in the development of features or applications. In this case, I recommend that you visit the following link: https://feedbackportal.microsoft.com/feedback/.
    Once there, please create a post to share the details of the issue you're facing.
    This action will help you connect with other users who are experiencing the same problem. When a post receives a high level of interaction, it encourages Microsoft’s product development team to prioritize fixing the issue more quickly.
    Thank you for your understanding and cooperation.
    If you have any updates regarding the issue, or if you have any other questions or concerns, please feel free to share them with me. I’m here to support you.
  2. Bob Jones AKA CyberTaz MVP 437.7K Reputation points
    2025-09-21T00:48:35.0266667+00:00
    Please clarify: You wrote Excel for Mac but refer to iOS which is the Apple operating system for their mobile devices, not Mac computers. Mac Computers run on macOS.
    The Index function requires that an Array be specified. With an array entered does the issue persist? If the issue is on a Mac please indicate the current Version Numbers of both macOS & Office.
