planner premium plans say i not part of thr team when i'm the owner
David Dunne 0 Reputation points
2025-09-18T13:25:49.01+00:00
I added a Planner Premium plan and started to set it up, but then I noted that I couldn't and asked someone to add me to the team for permissions. I am the team owner and have a Planner and Project 3 license. Conversion of basic plans to premium fails, too. I am trying to get this to run smoother before Business tries to get me to use a different non-Microsoft product.
Microsoft Teams | Microsoft Teams for education | Teams and channels | Create a new team or channel
    2025-09-18T14:56:11.9366667+00:00
    Hi @David Dunne
    Welcome to Microsoft Q&A forum
    I completely understand how frustrating it must be to run into setup issues with Planner Premium. I am here to work through it with you.
    To better understand, may I clarify a few details:
    1.Are you seeing any specific error messages or codes when you try to set up Planner Premium or convert a basic plan to premium? If so, could you share the exact error message or a screenshot?
    2.Can you confirm the exact license name in the Microsoft 365 admin center? Has the license been active for more than a few hours?
    3.When converting a basic plan to premium, at what step does it fail? For example, does it fail when you select the plan, during the conversion process, or when accessing the converted plan?
    4.Have you tried creating a new premium plan from scratch instead of converting an existing one?
    In the meantime, I suggest you check a few things for further investigate:
    1.Add Yourself as a Member
    Even as a team owner, you may not be automatically added as a member of the Microsoft 365 group, which is required to create or edit Planner plans:
    -Open Outlook (desktop app or web at outlook.office.com).
    -Navigate to Groups (or search for "Groups" in the search bar).
    -Find the Microsoft 365 group tied to your Teams team.
    -Select Request to join group. As the owner, this will be auto-approved instantly.
    (Reference: Resolving Permission Issues When Adding a Planner Tab to a Teams Channel - Microsoft Support
    2.Verify License
    Please contact your IT admin in your organization to verify the license has propagated correctly by:
    -Go to Microsoft 365 admin center (admin.microsoft.com) > Users > Active users > Select your account > Licenses and apps
    -Confirm the "Project Plan 3" license is assigned and active. If recently added, wait 15–30 minutes (up to a few hours) and try again.
    3.Check Organization Settings
    -An IT admin should go to Microsoft 365 admin center > Settings > Org settings > Project
    -Ensure "Project for the web for your organization" and related options (like syncing views) are enabled.
    Reference: Turn Project for the web or Roadmap on or off for users in your organization - Project for the web
    Note:
    -If you’re an end-user, please coordinate with your Office 365 Global Administrator to handle these steps.   
    -If you’re unsure who the Global Admin is within your organization, you can find guidance on locating them here: How do I find my Microsoft 365 admin? - Microsoft Support.  
    The initial response may not immediately address your needs, but it will help me better understand your situation. Thank you for your patience while we work through it
