How to fix huge delays when i mirror PC screen to Smart TV by WiFi direct ?
Валерій Єщенко 0 Reputation points
2025-09-17T13:07:46.2933333+00:00
How to fix huge delays when mirroring PC (Windows 10 64bit) screen to Smart TV by WiFi direct ?
The problem: Connection between PC (Windows 10 64bit) and Smart TV is unstable and delays are huge.
Classroom PC intention is demonstration Word docs and PowerPoint presentations and browser content e.g. Yotube video mirroring using Smart TV large screen.
I can not use HDMI cable to mirror PC screen to Smart TV.
That's why I use WiFi direct connection to use Duplicate variant when pessing Win+P.
The connection is unstable and delays are huge.
Are there any settings on PC and Smart TV (LG) to fix this trouble ?
DLNA and streaming mp4 and mp3 files by media player to Smart TV aren't the solution because it needs to mirror open Word's and PowerPoint presentations and browser content (e.g. Yotube video) to Smart TV large screen.
Probably are there any third party software (freeware) to solve this problem ?
Windows for home | Windows 10 | PC projection
  1. IGYQ 22,055 Reputation points Independent Advisor
    2025-09-17T13:50:15.4466667+00:00
    Hi!
    May I ask what is the reason why HDMI cannot be used to connect to the TV? (this is the best connection and ensure no lags or stutters)
    To ensure you're experience will have less lags, stutters and disconnections please follow the steps below.(via Wi-Fi Direct)
    1. Update Drivers
      • On your PC, update:
      • Wi-Fi adapter driver
      • GPU driver (Intel, NVIDIA, AMD)
      • Display driver (WDDM must support Miracast)
      Outdated drivers are the #1 cause of Miracast delays.
    2. Check Wireless Band
      • Both PC and TV to use 5 GHz Wi-Fi instead of 2.4 GHz.(if 5gz is available)
      • In Device Manager → Network Adapter → Properties → Advanced → Preferred Band → set 5 GHz.
      • On your router/TV, ensure they’re also on 5 GHz.
    3. Reduce Display Resolution
      • When connected, try lowering PC display resolution to 1920×1080 or 1280×720.
      • 4K or high refresh rates kill performance over Wi-Fi Direct.
    4. Disable Bluetooth Temporarily
      • Bluetooth shares the 2.4 GHz spectrum and can interfere with Miracast.
      • Turn it off during presentations if possible.
    5. Close Heavy Background Apps
      • Anything using the network (OneDrive sync, Windows Update, Teams calls) will add stutter.
      • Run your demos with only necessary apps open.
    6. Smart TV Settings (LG)
      • On LG TVs, under All Settings → Connection → Screen Share:
      • Ensure “Miracast / Wireless Display” is enabled.
      • Some models have Screen Share → Fast Connection mode — enable it if available.
