Point-To-Site VPN client Connection Manager needs elevated privilege - Policy Match error 13868
Salam ELIAS 302 Reputation points
2025-09-16T11:47:36.69+00:00
I have created a Virtual WAN then a hub point-to-site with server configuration using certificate. I downloaded the "Virtual Hub User VPN profile" to my laptop where client certificate is setup, ran VpnClientSetupAmd64.exe then go to VPN settings I see the VPN connection created. I click to connect I get the following 2 messages
I click on continue I get
Not really sure how to run this as admin and which policy is erroring. Thanks for your help.
Azure NAT Gateway
Azure NAT Gateway
NAT Gateway is a fully managed service that securely routes internet traffic from a private virtual network with enterprise-grade performance and low latency.
Praveen Bandaru 11,800 Reputation points Microsoft External Staff Moderator
2025-09-18T08:31:58.4833333+00:00
Hello Salam ELIAS
If you are using certificate authentication, please ensure the client certificate is properly installed on your local machine and that the root certificate is correctly uploaded in the Azure portal configuration.
For testing, remove the certificate from your local machine, then reinstall the client certificate. Delete the existing VPN client file and the old client certificate from your local machine, download a new VPN client file, install it, and test the setup. Let us know the results.
Additionally, these certificates should be included in the Microsoft trusted CA authority list. Please check the below public document:
https://learn.microsoft.com/en-us/azure/vpn-gateway/vpn-gateway-certificates-point-to-site
Hope the above answer helps! Please let us know do you have any further queries.
Please do consider accepting answer and “up-vote” wherever the information provided helps you, this can be beneficial to other community members.
0 additional answers
