Inserting Live document links in OneNote and Embedded view is only showing Microsoft 365 Sign in link. not the document
Bree Parker 0 Reputation points
2025-09-15T11:22:44.8133333+00:00
Inserting Live document links from share point in OneNote for the Embedded view function. However, the embedding tool box is only showing Microsoft 365 Sign in link. not the documentUser's image
Microsoft Teams | Microsoft Teams for education | Class Notebook | Other
  1. Alina-Le 6,395 Reputation points Microsoft External Staff Moderator
    2025-09-15T14:37:51.4333333+00:00
    Hello @Bree Parker
    Welcome to Q&A forum!
    Thank you for posting your query. To ensure we're aligned and I can provide you with better support, could you share a bit more information? Your details will help me assist you more effectively
    1. Are you using personal (hotmail.com, outlook.com) or educational (@edu_) or business account (@domain.com)?
    2. Could you clarify what type of document you're trying to insert into OneNote (an Excel link, a Word link, or another format?)
    You can also try to insert other link to see if you can see embedded view. If yes, the issue might be only related to this specific file.
    3. Are you using OneNote Web or Desktop?
    If you are opening OneNote in your Desktop, you can try to open the notebook in a browser (preferably Microsoft Edge) and test the embedded link there.
    4. Have you signed in with your Microsoft 365 account?
    • Embedded documents require authentication.
    • If the person viewing the OneNote page isn’t signed in, they’ll only see a Microsoft 365 sign-in prompt.
    Please kindly recheck to log in using their Microsoft 365 credentials.
    5. Do you have permission to access the document?
    • Even if signed in, they need access rights to the document stored in SharePoint or OneDrive.
    The owner can go to the document in SharePoint/One Drive→ click “Share” → choose “People with existing access” or “Anyone with the link” (if allowed by your organization)
    6. Is the document link a direct file link, not a folder or site link?
    • OneNote can only embed direct document links.
    • In SharePoint, click the document → choose “Copy link” → make sure it points directly to the file (e.g., ends in .docx, .pptx, etc.)
    7. How do you insert this document link to One Note (using copy + paste or using built-in tool of OneNote?)
    You can try to insert this document by following steps: Insert -> File Print out
    8. Are other users in your organization experiencing the same issue as you when embedding a link in OneNote?
    Please kindly check with your friend to see whether this issue is a common one or only happening to you
    Besides, you can also try these steps to see if it helps:
    Note:
    • Embedded previews aren't fully editable in OneNote, you'll need to open the document in Word to make changes, then refresh the preview (right-click the embed > Refresh).
    • If it still prompts for sign-in, right-click the embedded frame > Open in new tab, sign in to SharePoint/OneDrive, then return to OneNote, the preview should load.
    Additionally, I also searched for some Microsoft Article which is related to this issue, please take a look to see if it helps:
    Embed content in OneNote - Microsoft Support
    Please take your time to respond, and I'm here to work through this with you. We will try to figure it out together.
    I look forward to hearing from you for further assistance!
    Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.User's image
