cant generate achievement code for AZ-204
Trainocate Malaysia 10 Reputation points
2025-09-11T08:40:03.22+00:00
Hi ,
Kindly assist as we have issue cant generate the achievement code badge for few Microsoft courses.
AZ-204, PL-300, once we login we cant find the achievement code creation button.
Microsoft Teams | Microsoft Teams for education | Insights
  1. Fahad Q. Basrawi 85 Reputation points
    2025-11-26T07:53:05.4633333+00:00
    Hello, I am experiencing the same issue that other users have reported. The option to export or redeem my achievement code no longer appears in my Microsoft Learn account after completing courses. I have already tried signing out and back in, clearing my browser cache, and using private/incognito mode, but the problem persists.
    Could the support team please check this issue and let me know if there is a fix or an update available soon?
    Thank you in advance for your assistance.
  2. Tina L 12,430 Reputation points Microsoft External Staff Moderator
    2025-09-15T10:12:59.15+00:00
    Hello @Trainocate Malaysia,
    It’s been a while since I last heard from you; I just wanted to check in and see if you need any further assistance.
    I’m not sure if you’ve had a chance to check the update from the link I shared earlier.
    I reviewed it and saw that on September 11, Microsoft confirmed that the issue with Achievement Code Creation has been partially resolved.
    User's image The achievement code button has reappeared in some partner accounts, and while they’re optimistic the fix has reached all accounts, they’re still collecting feedback before declaring it fully resolved.
    You may want to check again to see if the feature is available in your account.
    If you're still experiencing the issue, you can reply directly to the discussion thread so Microsoft can continue evaluating any remaining access gaps and improve the product based on user needs.
    That discussion link: SOLVED (partial): Issue with Achievement Code Creation
    If you find this information helpful, please consider marking it as an answer. Once marked, it will automatically pin to top. As other users will also search information in this community, your valuable marked answer will definitely also help other users who have similar queries easily to find the correct channel and useful information more quickly.
    0 Accept answer v 1 answer PO Please feel free to let me know if there’s anything I can help with.
    Looking forward to hearing from you!
  3. Tina L 12,430 Reputation points Microsoft External Staff Moderator
    2025-09-11T09:31:36.56+00:00
    Thank you for reaching out to the Q&A forum!
    Although this issue is typically outside the scope of my usual support responsibilities, I’ve taken the time to research it and found that Microsoft is currently working on a fix.
    undefined
    You can refer to the official update from Microsoft posted on September 5 via this link: September 5 Update: Issue with Achievement Code Creation | Microsoft Community Hub
    This update confirms that Microsoft is actively working to resolve the issue affecting achievement code creation for several courses, including AZ-204 and PL-300. The fix is being rolled out progressively, so you may want to check back periodically or monitor the Tech Community thread for further updates.
    While waiting for Microsoft to resolve the issue, please make sure that you’ve already confirmed the following:
    You are signed in with the correct Class Administrator account that has been granted permissions through the Microsoft Learn for Educators program.
    You’ve tried basic troubleshooting steps such as:
    • Clearing your browser cache
    • Using InPrivate/Incognito mode to log in
    If the issue persists after these steps, you can refer to the link above for ongoing updates from Microsoft.
    Once again, thank you again for raising this issue; it’s helped broaden my understanding. I hope you understand that I want to help as much as I can within the scope of this forum.
    0 Accept answer v 1 answer Po
