How to fix explorer.exe restarting in loop
Breizh-Brittany 20 Reputation points
2025-09-10T07:02:36.4966667+00:00
I'm an average user and I have windows 10 Pro and tried since I bough it in 2020 to make the OS clean. I quickly learnt many things, like do not blindly follow advices from youtube videos of "experts" showing how to have a fast responsive computer. And rather learn each part of windows before changing it componants or anything.
Anyway, since several days I have big problem, even if I don't think I touched anything OS related since months.
Explorer.EXE restart in loop. I don't want to reinstall Windows.
The loop happen sometimes when I start the PC, sometimes when I put a game in Fullscreen and Always when I rotate the screen to portrait mode using NVidia Control Panel.
I tried many things already but I'm not expert so I probably missed something somewhere.
Another problem which I should mention, although I'm not sure if it's related as I have the problem since 2 years now:
PC do not start sometimes, It goes on until bios then screen lost connection, PC's still turning. I have to reset and then it always turn on properly.
Please tell me anything you have in mind, expert or casual, I need fresh ideas!
Yours,
.Mathieu
Config
MB: Gigabyte B450 AORUS ELITE
PSU: Corsair RM1000x
CPU: AMD Ryzen 5800x3D
RAM: 4x16Go DDR4 Crucial Pro CP2K16G4DFRA32A
GPU: NVidia GeForce MSI Suprim RTX 3090Ti
SSD: NVMe SanDisk Force MP510 480Go
  • 3 other storages including 1 HDD 7200rpm with the Pagefile.sys set to 64Go on it.
DaveM121 935.7K Reputation points Independent Advisor
2025-09-10T07:37:43.3133333+00:00
Your detailed description of the problems indicate the Windows instalaltion is corrupt, the best option to stabilise your Windows installation is to perform an in-place repair with the Windows 10 ISO.
Please ensure you download the ISO in the same language as you use for the Windows UI, follow the steps, this is then not like re-installing Windows, it is just like an update and your personal files, settings and installed software will not be affected.
Click this link:
https://www.microsoft.com/software-download/windows10
to download the Media Creation Tool (Click on Download Tool Now), with that you can download the latest Windows 10 ISO (Select Create Installation Media for Another PC), then choose ISO, not USB
When the ISO file completes downloading
Disconnect from the Internet
Disconnect all external devices with the exception of a mouse or keyboard.
Temporarily disable any 3rd party Anti-virus you may have installed
Then, in Windows File Explorer, double click the ISO and then run Setup.exe and select the Install option.
Very Important - ensure you select the option to keep your files and apps.
0 additional answers
