received: An input field is invalid. Please check your input fields and try again.
Ali Bizmark 30 Reputation points
2025-09-08T23:54:53.86+00:00
Hi
When I want to complete my address for book an exam always received:
there is not any special character and my address is valid as well
Anshika Varshney 15,625 Reputation points Microsoft External Staff Moderator
2025-09-09T08:49:58.4+00:00
Hi Ali Bizmark,
Thank you for reaching out on the Microsoft Q&A.
The error “An input field is invalid” usually happens when one of the address fields does not meet the validation rules, even if the address looks correct. Common causes include exceeding character limits (e.g., names or address lines too long), using restricted symbols (like #, @, or &), or entering values that don’t match the required format (such as postal codes or phone numbers).
To fix this, re-enter your details using only letters, numbers, commas, or periods, keep each field within its character limit, and double-check that all required fields (street, city, postal code, country) are filled in correctly. If your address is long, split it across multiple lines instead of entering everything in one field.
Example of an accepted format:
Address Line 1: 123 MG Road
Address Line 2: Sector 15, Near City Mall
City: Noida
State/Province: Uttar Pradesh
Postal Code: 201301
Country: India
Using this structure usually resolves the validation error and lets you proceed with booking.
Please find the attached documents for your reference:
I hope this clears things up! If this guidance resolves your concern, please consider accepting the answer so other community members exploring production scenarios with Content Understanding can benefit from it as well.
Thankyou!
0 additional answers
