Hacked not receiving emails
Tierney 17 25 Reputation points
2025-09-08T14:22:51.55+00:00
I was hacked. I changed my password and turned off email forwarding, but I’m still not receiving inbox emails, only receiving junk emails. Please advise,
EmilyS726 266.6K Reputation points Independent Advisor
2025-09-08T19:41:36.84+00:00
Make sure you do this on a computer, not on smartphone or tablet. Go to https://www.outlook.com and log in, click on the gear icon in the top right to launch the settings.
Then, on the Mail tab, go to Rules. Are there any rules set up here? If yes, delete them all.
Then check the conditional transfer, again, if it's there, delete it.
Then, check Forwarding and IMAP, If any items are present, delete them as well.
If you can't find anything, go to https://account.live.com > Your info > Sign in Preferences. Make sure to check all the aliases here. If you don't recognize any there, delete it.
Then go to Security > Manage How I sign in, make sure all contact info is yours.
Please make sure you change your password and enable two-step verficiation.
0 additional answers
