Surface Pro 9 – USB-C Charging Issue
Maher Loubani 0 Reputation points
2025-09-01T20:47:32.68+00:00
My Surface Pro 9 charges normally with the original magnetic charger, but it does not charge through USB-C. I have tested with a certified 65W+ PD charger and cable, tried both ports, updated Windows and firmware, and performed a reset, but the issue remains.
As the magnetic charger works, the battery seems fine. The problem appears limited to the USB-C ports. Please advise on repair or service options
Surface | Surface Pro | USB-C
  1. JANSHER LIWAG 8,955 Reputation points Independent Advisor
    2025-09-04T19:43:23.8+00:00
    Hi Maher,
    Thank you for posting and sharing your prior troubleshooting. Possible cause that you are getting this problem might be faulty charging port, damaged cable or software problem.
    To fix the problem let us try to this steps.
    Try to check if any Debris or object blocking the 2 USB C port.
    Do a force restart tap the Start button then tap the power and choose shut down. After 10 seconds press and hold the power button for 20 seconds. Wait until the Windows Logo appears, disappears and appear again. After this try to charge again using USB C.
    You can use this article for additional steps  https://support.microsoft.com/en-us/surface/troubleshoot-problems-with-usb-c-on-surface-e32fea6d-8df1-eda6-1a8b-a1d1b88fd62e
    Let me know how this goes. If you need more help please feel free to let me know.
    Best regards,  Jansher
