Microsoft Connected Cache verification stuck after provisioning (IoT Edge running but portal not moving forward
Al Jazeera Telecom 0 Reputation points
2025-09-01T05:52:11.9366667+00:00
I have provisioned Microsoft Connected Cache (MCC) for ISPs on my server mcc-jazeera-cache01.
The IoT Edge modules (edgeAgent, edgeHub, SimulatedTemperatureSensor) are running.
DNS configuration is set correctly, containers can resolve mcr.microsoft.com.
However, in the Azure portal, under Verify Operator, it is stuck at:
“Congratulations, you are now verified. Please wait for a few minutes and refresh your page to move onto the next step.”
This status has not changed for more than 24 hours.
Because of this, I am not receiving any credentials (username/password) for Connected Cache.
Could you please assist me in finalizing the verification process or let me know if I need to trigger a backend refresh?
Thank you.
Azure IoT Edge
Azure IoT Edge
An Azure service that is used to deploy cloud workloads to run on internet of things (IoT) edge devices via standard containers.
  1. Manas R Mohanty 17,270 Reputation points Moderator
    2025-09-04T12:29:40.6233333+00:00
    Hi Al Jazeera Telecom,
    Logs will help debug the Issue
    You can enable the verbose with CLI commands too
    https://learn.microsoft.com/en-us/cli/azure/mcc?view=azure-cli-latest
    Please re-register service provider for underlying respective services if needed.
    Looking forward to hearing from you.
    Thank you
