HOW DO I ENABLE CAMERA IT IS SAYING I NEED TO UNBLOCK OR TUEN ON SWICT. THE CAMERA IS ENABLED BUT I DONT KNOW WHICH SWITCH TO USE TO TURN IT ON
Shanice Bryan 10 Reputation points
2025-08-31T04:40:58.2433333+00:00
  1. Lychee-Ng 28,915 Reputation points Microsoft External Staff Moderator
    2025-08-31T09:11:43.69+00:00
    Hi Shanice Bryan,
    Welcome to Microsoft Q&A!
    Thanks for sharing, and I'm sorry to hear you're facing such a frustrating issue. You are not alone! Other users have previously reported similar behavior with their camera, with some worked solutions you can check out here: Your camera is reporting that it is blocked or turned off by a switch or button on your device. - Microsoft Q&A
    1 - Look for a physical camera shutter switch:
    • Many modern HP laptops have a literal physical slider switch that you can slide with your finger. It's often near the camera lens, or under the laptop (less likely but worth checking).
    • Run your finger along the top edge of your laptop's screen, right where the camera lens is. If you feel a small switch, slide it to the "open" or "unblocked" position.
    2 - Use the function key (Fn) on the Keyboard
    • There is usually a shortcut button on the top row (F1-F12) that you can use to turn the camera on or off.
    • Find a key with camera icon. It's often F9 or F10 on HP laptops, but it can vary depends on your model.
    • Press the button if it's already media key, if not, try pressing the combination of Fn key + the camera key.
    If the issue persists, it could be very helpful for further analysis if you can share System Information: Press Win + R > type msinfo32.exe > Enter > copy the information or take a screenshot of the window (remember to hide private info). Thank you for your patience and cooperation!
    If the answer is helpful, please click "Accept Answer" and kindly upvote it to assist others who might face similar issues. If you have extra questions, please click "Comment".
    Note: To enable e-mail notifications, follow the steps in our documentation!
  2. Lychee-Ng 28,915 Reputation points Microsoft External Staff Moderator
    2025-09-03T08:55:37.1966667+00:00
    Hi Shanice Bryan,
    Just checking in to see if the above information was helpful. If you have any further updates on this issue, please feel free to post back. If everything worked out, please remember to mark it as an answer. Warm thanks.
  3. Majibur Rahman 0 Reputation points
    2026-07-13T10:28:57.2266667+00:00
    First of all, I would like to say Thank You for the most useful information. For last 2 hours, I was facing the same problem with my camera. But now, it was solved with your clear answer. It was the physical slider switch that blocked my camera. I cleaned up the camera and camera was blocked with the almost unvisible slider.
    Once again, Thanks a lot
