how to fix Unattend.XML issue during OS upgrade
2025-08-21T10:08:44.97+00:00
We have change the key and rename the Unattend.XML file in C:\Windows\Panther and still same issue in different servers. For e.g. Windows 2008 R2 to 2012 R2 fails and from 2012 to 2016 fails with same error.
Windows for business | Windows Server | Devices and deployment | Set up upgrades and drivers
  1. Harry Phan 31,780 Reputation points Independent Advisor
    2025-08-21T14:43:59.9066667+00:00
    Dear Lalith Sanchethi,
    We understand how critical smooth transitions are, especially when working across multiple Windows Server versions. If the same error persists despite updating the product key and renaming the Unattend.XML file in C:\Windows\Panther, it’s possible that the file contains legacy or unsupported settings that are incompatible with newer OS versions. We recommend reviewing the XML structure and validating it against the target version’s documentation to ensure all components are supported. Additionally, consider generating a fresh Unattend.XML using Windows System Image Manager tailored to the destination OS.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    Best regards,
    Harry Phan
