my Microsoft store is not opening my current laptop uses windows 8.1 version
Syed Motbahar 0 Reputation points
2025-08-16T05:33:13.65+00:00
My current laptop version is "windows 8.1". My Microsoft Store is not opening it is just showing "Screenshot (2).png " and does not go any further. I have tried rebooting it by using "wsreset.exe" command but it has no effect. Kindly provide me with a possible way to make it work as I currently cannot upgrade my device's OS for the time being.
Windows for home | Previous Windows versions | Microsoft Store
    2025-08-16T15:53:03.93+00:00
    Dear Syed Motbahar,
    It's frustrating when the Microsoft Store gets stuck on the loading screen like that. The primary reason this is happening is that Microsoft officially ended all support for Windows 8.1 on January 10, 2023. This means the servers that the Store app needs to connect to may no longer be available for this version of Windows, which can cause it to hang indefinitely.
    While a permanent fix may not be possible without upgrading your OS, here are a few troubleshooting steps you can try to resolve potential software conflicts on your laptop.
    1. Run the Windows Store Apps Troubleshooter:
      • Move your cursor to the bottom-right corner of the screen to bring up the Charms Bar.
      • Click Search and type troubleshooting.
      • Select Troubleshooting from the results to open the Control Panel window.
      • On the left pane, click View all.
      • Find and click on Windows Store Apps to run the troubleshooter. Follow the on-screen prompts to let it detect and fix any issues.
    2. Re-register the Microsoft Store:
      • Press the Windows Key + X on your keyboard and select Windows PowerShell (Admin) from the menu.
      • Carefully type or copy and paste the following command into the blue PowerShell window and press Enter:
             Get-AppXPackage *windowsstore* | Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
      • Let the command finish running (you may see some text scroll by). Once it's done, restart your computer and try opening the Store again.
    3. Create a New Local User Account:
      • Go to Change PC settings > Accounts > Other accounts.
      • Click Add an account.
      • Choose Sign in without a Microsoft account (not recommended), then select Local account.
      • Fill in the details for a new user, log out of your current account, and log in to the new one. Try opening the Microsoft Store from this new account.
    If the Store works in the new account, it means your original user profile is the source of the issue.
    If none of these steps work, it unfortunately confirms that the problem is due to the end of support for Windows 8.1. The only long-term solution would be to plan for an upgrade to a supported operating system like Windows 10 or 11, hardware permitting.
    To assist others who might have similar questions and to help us improve our support system, we kindly encourage you to "Accept the answer" if it successfully addressed your concern. Accepting an answer lets other users know that this solution worked for you, and it also helps us track the effectiveness of our support efforts.
    Best regards,
    Bryan Vu | Microsoft Q&A Support Specialist
