GPO Options for Optional Component Installation Missing in Windows 11 24H2
Justin-6389 0 Reputation points
2025-08-15T18:47:34.1066667+00:00
Hope this is the right spot to ask this. If not, the if you can direct me where I should ask it at I'll take it to them. Please and thank you.
Encountering an issue with Group Policy where the settings for optional component installation are inconsistent across Windows versions. The administrative template can be found under Computer > Policies > Administrative Templates > Specify settings for optional component install and component repair.
While some computers configured with the GPO display two additional options:
  • "Never attempt to download payload from Windows Update" (to remain unchecked)
  • "Download repair content and optional features directly from Windows Update instead of Windows Server Update Services" (which should be enabled),
other computers with Windows 11 24H2 OS build 26100.4652 or greater do not show these additional fields. In contrast, they appear on devices running Windows 11 23H2 OS build 22631.5699 and earlier, as well as Windows 10 devices.
A screenshot illustrating this issue is provided below:
Screenshot 2025-08-15 141941
Any insights on why these options are missing in the latest Windows 11 build would be appreciated.
Windows for business | Windows Client for IT Pros | Directory services | Deploy group policy objects
  1. Erik Moreau 2,061 Reputation points MVP Volunteer Moderator
    2025-08-16T14:08:48.6833333+00:00
    Hi Justin,
    As Wsus has been deprecated, https://techcommunity.microsoft.com/blog/windows-itpro-blog/windows-server-update-services-wsus-deprecation/4250436
    This policy has been adjusted to by default download components directly from Windows Update and have the opportunity to get the components from a network location (and fall back to Windows Update if that fails)
    'If you disable or do not configure this policy setting, or if the required files cannot be found at the locations specified in this policy setting, the files will be downloaded from Windows Update, if that is allowed by the policy settings for the computer.'
    Before the change in 24H2 the option to receive them from WSUS made the policy more complex as follow WSUS settings was the default and direct Windows Update or local share were the other options.
    To enable the settings you describe above you would no longer need to set the GPO or set it to disabled to force the setting
    If you want to doublecheck the impact oof the GPO through registry, it is set here: HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Servicing
    Hope this helps,
