How to fix an issue where a black bar is covering my sheet tabs in Excel
Connor Otterbeck 135 Reputation points
2025-08-11T09:53:40.88+00:00
Capture
In Excel within Citrix, a black bar appears at the bottom of the window, obscuring the sheet tabs. This issue occurs across multiple workbooks and machines, making it difficult, but not impossible, to navigate between sheets.
I have attached a screen capture from one of our users that shows the issue.
I am not exactly sure on the steps to reproduce as it seems to happen at random when switching between applications within Citrix.
This is happening since last week but is not affecting all the users at once across our business.
To attempt to fix this issue we have:
  • Disabled hardware graphics acceleration.
  • Verified no third-party add-ins are installed.
  • Adjusted display scaling and resolution.
Any help would be appreciated.
Edit:
Please Read:
As stated by BclemZ in a comment on T J's answer the current workaround is to switch to the semi-annual channel and downgrade to Version 2506 (Build 18925.20184). This has worked for us and we have not gotten another report of it happening since we downgraded a month ago.
However there is no official fix yet
Tina L 12,435 Reputation points Microsoft External Staff Moderator
2025-08-18T07:38:15.98+00:00
(The lasted update: The official workaround has been added as a comment below this answer)
Latest Update as of August 18 – Potential Microsoft 365 Service Incident
Hello @Connor Otterbeck and everyone in this thread
Thank you @Connor Otterbeck for the update in the support ticket.
According to the latest response from our Microsoft technical support, the issue we’re experiencing might be related to a broader Service Incident (SI) within the Microsoft 365 environment. However, this incident has not yet been officially published on the Microsoft 365 Service Health Dashboard.
Based on Connor Otterbeck's screenshot:
While we wait for further confirmation from our Microsoft technical support, let’s all stay patient and continue monitoring the situation.
I’ll share any new updates as soon as they become available.
28 additional answers
  1. AlexM 40 Reputation points
    2025-08-14T10:39:56.3566667+00:00
    Getting exactly the same issue reported.
    excelissue2
    Windows Server 2019
    Microsoft Office 365 version 2507 build 19029.20156
    We don't use Citrix - users connect via RDP
    The only application which appears effected is Excel.
    Work around seems to be close excel and re-open it multiple times and its hit/miss if this resolves the issue for a short time, but it always comes back eventually.
    Also noted that in addition to the black bar covering the sheets in the workbook, the minimise/maximise and close button also don't display correctly, which also looks to be an issue on Connors original screengrab.
    excelissue
  2. Tina L 12,435 Reputation points Microsoft External Staff Moderator
    2025-08-14T13:10:25.1633333+00:00
    Hello @Connor Otterbeck and everyone in this thread,
    I’ve seen that many organizations are currently experiencing.
    At the moment, this issue has not yet been acknowledged as an official incident in the Microsoft 365 Service Health Dashboard. That means it’s important for us to report it directly to Microsoft so they can investigate and prioritize a fix.
    I strongly encourage you (and others affected) to report the issue directly from within Excel using the “Help > Feedback” option.
    undefined
    Every report contributes to improving the product, and it’s often thanks to real-world usage and insights like yours that the dev team can prioritize fixes in upcoming updates.
    I’ll also submit a report from my side. Let’s keep each other updated if we hear anything back!
    Besides that, please follow these steps in my previous to raise a ticket if you want to reach out to higher technical support.
    If you find this response helpful, please mark it as “Accepted Answer” so others with the same issue can easily find it. The more reports Microsoft receives, the more visibility the issue will get with the development team.
  3. AsifKhetab-1868 20 Reputation points
    2025-08-14T13:57:06.66+00:00
    anyone tried updating Office to 19029.20184 ?
  4. T J 10 Reputation points
    2025-08-14T16:12:23.96+00:00
    Just got this from MS support this morning
    Confirmed issue details
    Environment Affected: Windows Server 2019 RDS, Citrix, Horizon desktop environments
    Excel Version: Microsoft 365 MSO (Version 2507 Build 16.0.19029.20136), both 32-bit and 64-bit
    Symptoms:
    Black bar intermittently appears at the bottom of Excel, hiding sheet tabs
    Menu/ribbon options may disappear
    Theme colors not displaying in dropdowns
    Issue typically occurs within 1–2 hours of Excel usage
    Likely Root Cause
    The issue appears to be related to UI rendering problems caused by Citrix VDA 2402 or similar virtualization layers. These platforms may mishandle Excel's graphics rendering, especially when:
    Switching between applications
    Using multiple monitors
    Running Excel in full-screen mode
    Why It Happens:
    Citrix and Horizon use virtual display drivers and GPU passthrough (e.g., NVIDIA vGPU)
    Driver mismatches between host and guest VMs can cause UI glitches
    Hardware acceleration in Office apps may conflict with virtual drivers
    Excel’s rendering engine expects consistent GPU behavior, which virtualization layers may not guarantee
    Horizon 8 users with NVIDIA GPUs have also reported similar issues in Excel and Outlook
    Workarounds & Fixes :
    Rename Excel Cache File
    Path:
    C:\Users<username>\AppData\Local\Microsoft\Excel\CatalogCacheMetaData.xml
    Rename to CatalogCacheMetaData_old.xml and restart Excel
    Effect: Temporarily resolves the black bar issue
    Disable Hardware Graphics Acceleration
    Go to File > Options > Advanced > Display
    Check "Disable hardware graphics acceleration"
    Restart Excel
    Avoid Full-Screen Mode
    Use Excel in windowed mode, especially with multiple monitors
    Resize or minimize/maximize the window to force a redraw
    Use Keyboard Shortcuts
    Use Ctrl + Page Up / Page Down to switch sheets when tabs are hidden
    Switch Update Channel
    Users have reported that the Semi-Annual Channel is unaffected
    Consider switching from Monthly Enterprise Channel to Semi-Annual
    Reset Graphics Driver
    Press Win + Ctrl + Shift + B to reset the graphics driver
    Helps in some cases with rendering glitches
    Check Display Scaling
    Set display scaling to 100%
    Avoid custom scaling settings that may interfere with rendering
    Below are the recommendations
    Update Citrix VDA or Horizon Agent to the latest stable version
    Match GPU driver versions between host and guest VMs
    Disable hardware graphics acceleration in Excel
    Avoid full-screen mode; use windowed mode and resize to force redraw
    Switch to the Semi-Annual Channel for Excel if possible
