Microphone Buttons Disappearing In Breakout Rooms Teams
Tr. Girasol 100 Reputation points
2025-08-07T13:25:03.3766667+00:00
We're having some problems with Teams breakout rooms. Some of the attendees are missing their mics and can't use mics when they join the breakout rooms. It's happening in almost all the meetings. May I know any solutions for this?
Microsoft Teams | Microsoft Teams for education | Meetings and calls | Audio and video
Liora D 18,915 Reputation points Microsoft External Staff Moderator
2025-08-08T09:26:46.92+00:00
Hi everyone,
Thanks for sharing your experiences, it’s clear this microphone issue in breakout rooms is affecting quite a few users across different setups. I’ve seen reports from both desktop and web users, mainly on Windows, and it seems to happen consistently inside breakout rooms, while everything works fine in the main meeting.  This looks like a recent issue, possibly tied to a Teams update. It’s not limited to one organization or device type, which suggests it may need investigation from the backend side.
  While we wait for more clarity, here are a few things that have helped some users:
  • Minimize and maximize the Teams window once inside the breakout room this may refresh the UI and bring the mic button back.
  • Leave and rejoin the breakout room.
  • Use Teams Web App via https://teams.microsoft.com in Edge or Chrome.
  • Check breakout room settings: If you’re the organizer, make sure “Participants can unmute themselves” is enabled.
  • Verify mic permissions in Teams settings: Go to Settings > Devices and confirm the correct mic is selected.
I’re escalating this issue internally so the engineering team can take a closer look. If you’re an IT admin, I recommend submitting a support ticket via the Microsoft 365 Admin Center and checking the Service Health Dashboard for updates.
For detailed instructions on how to get support, please refer to Get support - Microsoft 365 admin.
I'm truly appreciate your patience and detailed feedback. Your reports are helping us better understand the scope and urgency of this issue. Please continue to share any new findings, and we’ll keep you updated as soon as we have more information from the backend investigation.
8 additional answers
  1. Valitutto,Paul 0 Reputation points
    2025-08-20T16:23:53.3666667+00:00
    We also are experiencing the issue. Our guess is a versioning issue, but we believe we have a work around. If the Mute button is missing, using the keyboard combo Windows+Alt+K seemed to bring it back. Some had to use Ctrl-Shift-M at that point to mute/unmute once the button was back.
  2. Chris Sherman 0 Reputation points
    2025-08-13T17:07:44.12+00:00
    This just started happening to us this week as well. Working with my end users but this is becoming problematic.
  3. Grobler, Dalene - Contractor {PI} 0 Reputation points
    2025-08-12T10:21:58.8066667+00:00
    Hi all.
    We've used the following to overcome the issue and it seems to work for most:
    1. CNTRL+SHift+M
    2. F8
    3. Shift + F4
    4. Minimise the meeting window, and it shows the physical mic sign, even it's not visible on full mode screen.
    2025-08-11T15:17:30.58+00:00
    We are having the same issue. Seems like people with headsets / headphones with built in mute buttons experience the problem and people not using headsets do not.
