Managing external identities to enable secure access for partners, customers, and other non-employees
Exception thrown when using /userinfo in Azure B2C custom policies
We have set up oAuth2 idp and for customendpoint we use /userinfo endpoint of the openid IDP.
We have tried various things but continue to get the exception - "AADB2C: An exception has occurred" and not much other information even in insights except the below:
We are using the following Technical Profile:
<TechnicalProfile Id="iddataweb-OIDC-userinfo">
us/answers/questions/2247510/problem-adding-external-identity-provider-with-azu -->
<DisplayName>IDW Login</DisplayName>
<Protocol Name="OpenIdConnect" />
<Metadata>
<Item Key="issuer">https://iddatawebb2c.b2clogin.com/your-tenant-id/v2.0/</Item>
<Item Key="authorization_endpoint">https://preprod1.iddataweb.com/axn/oauth2/authorize</Item>
<Item Key="AccessTokenEndpoint">https://preprod1.iddataweb.com/axn/oauth2/token</Item>
<Item Key="ClaimsEndpoint">https://preprod1.iddataweb.com/axn/oauth2/userInfo</Item>
<Item Key="client_id">someid</Item>
<Item Key="response_types">code</Item>
<Item Key="response_mode">query</Item>
<Item Key="scope">openid profile</Item>
<Item Key="HttpBinding">POST</Item>
<Item Key="UsePkce">true</Item>
<Item Key="UsePolicyInRedirectUri">false</Item>
</Metadata>
<CryptographicKeys>
<Key Id="client_secret" StorageReferenceId="B2C_1A_secret" />
</CryptographicKeys>
<OutputClaims>
<OutputClaim ClaimTypeReferenceId="issuerUserId" PartnerClaimType="sub" />
<OutputClaim ClaimTypeReferenceId="displayName" PartnerClaimType="sub" />
<OutputClaim ClaimTypeReferenceId="givenName" PartnerClaimType="sub" />
<OutputClaim ClaimTypeReferenceId="surname" PartnerClaimType="sub" />
<OutputClaim ClaimTypeReferenceId="identityProvider" DefaultValue="cylogin" />
<OutputClaim ClaimTypeReferenceId="authenticationSource" DefaultValue="socialIdpAuthentication" />
</OutputClaims>
<OutputClaimsTransformations>
<OutputClaimsTransformation ReferenceId="CreateRandomUPNUserName" />
<OutputClaimsTransformation ReferenceId="CreateUserPrincipalName" />
<OutputClaimsTransformation ReferenceId="CreateAlternativeSecurityId" />
<OutputClaimsTransformation ReferenceId="CreateSubjectClaimFromAlternativeSecurityId" />
</OutputClaimsTransformations>
<UseTechnicalProfileForSessionManagement ReferenceId="SM-SocialLogin" />
</TechnicalProfile>
and user journey as
<UserJourney Id="SignUpOrSignInWithExternalOAuth2">
<OrchestrationSteps>
<!-- Step 1: Check for existing session -->
<OrchestrationStep Order="1" Type="CombinedSignInAndSignUp" ContentDefinitionReferenceId="api.signuporsignin">
<ClaimsProviderSelections>
<ClaimsProviderSelection TargetClaimsExchangeId="ExternalOAuth2Exchange" />
</ClaimsProviderSelections>
</OrchestrationStep>
<!-- Step 2: Show error if IDP selection failed -->
<!-- <OrchestrationStep Order="2" Type="ClaimsExchange">
<Preconditions>
<Precondition Type="ClaimsExist" ExecuteActionsIf="true">
<Value>objectId</Value>
<Action>SkipThisOrchestrationStep</Action>
</Precondition>
</Preconditions>
<ClaimsExchanges>
<ClaimsExchange Id="SelfAsserted-Unified" TechnicalProfileReferenceId="SelfAsserted-Unified" />
</ClaimsExchanges>
</OrchestrationStep> -->
<!-- Step 3: Redirect to external OAuth2 provider -->
<ClaimsExchanges>
<ClaimsExchange Id="ExternalOAuth2Exchange" TechnicalProfileReferenceId="iddataweb-OIDC-userinfo" />
</ClaimsExchanges>
<!-- Step 4: Read user attributes from UserInfo endpoint -->
<OrchestrationStep Order="3" Type="ClaimsExchange">
<Preconditions>
<Precondition Type="ClaimEquals" ExecuteActionsIf="false">
<Value>identityProvider</Value>
<Value>externalprovider.com</Value>
</Precondition>
</Preconditions>
<ClaimsExchanges>
<ClaimsExchange Id="AADUserReadWithObjectId" TechnicalProfileReferenceId="AAD-UserReadUsingObjectId" />
</ClaimsExchanges>
<!-- Step 5: Create or update local account -->
<OrchestrationStep Order="4" Type="ClaimsExchange">
<ClaimsExchanges>
<ClaimsExchange Id="AADUserWrite" TechnicalProfileReferenceId="AAD-UserWriteUsingAlternativeSecurityId" />
</ClaimsExchanges>
<!-- Step 6: Enrich claims if needed -->
<!-- <OrchestrationStep Order="5" Type="ClaimsExchange">
<ClaimsExchanges>
<ClaimsExchange Id="EnrichClaims" TechnicalProfileReferenceId="EnrichClaimsFromUserInfo" />
</ClaimsExchanges>
<!-- Step 7: Issue tokens -->
<OrchestrationStep Order="5" Type="SendClaims" CpimIssuerTechnicalProfileReferenceId="JwtIssuer" />
</OrchestrationSteps>
<ClientDefinition ReferenceId="DefaultWeb" />
</UserJourney>
Any help would be appreciated
Microsoft Security | Microsoft Entra | Microsoft Entra External ID
Deleted
