IOT DNS request for BLOB storage connection
Joseph Castelnovo 0 Reputation points
2025-07-26T06:50:16.42+00:00
I am trying to figure out how an on prem IOT with private IP does the initial connection to connect to blob storage. It is behind a NAT gateway to the Internet.
I read IOT devices built to use AZURE Blob Storage have a preconfigured DNS address 168.63.129.16. The Azure private resolver What DNS resolution request is being sent from the IOT to the resolver. (something) [hostname].blob.core.windows.net:443 ssl. The Azure private resolver returns what ? A configuration message that provides hostname, connection logon information ?
I am lost on how the connection proceeds. Some SSL tunnel that connects to an AZURE Private IP configured by the Tennent. So no traffic ever has access to the Internet.
Azure IoT Edge
Azure IoT Edge
An Azure service that is used to deploy cloud workloads to run on internet of things (IoT) edge devices via standard containers.
  1. Manas R Mohanty 17,270 Reputation points Moderator
    2025-08-05T06:03:18.64+00:00
    Hi Joseph Castelnovo
    It seems you are trying to pass data from on-prem data with a private IP to Azure Storage.
    We normally add the IOT devices through device connection string or X-509 or symmetric keys to destined Storages
    But it won't be straight forward as you have private IPs on your Prem IOT device so you would be needing to secure your storage and IOT Hub with private endpoints.
    and setup a conditional forwarder or DNS resolver on prem-DNS server to foreword the queries to Azure DNS server to look up private Ips for respective storage and IOT Hubs
    You also need modify to outbound traffic in your NAT Gateway or Network security group or firewall to allow outbound connection to Storage and IOT Hub private IPs.
    Once DNS resolution happens on storage and IOT hub with outbound traffic allowed on your on prem NAT Gateway, you send traffic to destined storage
    Sample Diagrams from on Prem IOT to Private Azure Storage
    generated_image
    Sample Diagram on Custom DNS from Azure ML (for Explaining DNS server and conditional forwarding to Azure DNS server)
    Diagram of custom DNS hosted in Azure topology
    Reference
    Register devices in IOT hub
    Route data from IOT hub to storage
    Custom DNS for Azure ML (for understanding on prem DNS server and conditional forewarding)
    Troubleshoot connection to devices
    Hope it gives the needed clarity on routing query from devices with on prem private IP to Azure private resources.
    Thank you
