A web-based tool in Microsoft 365 that enables users to quickly create surveys, quizzes, polls, and feedback forms.
Hi! Newer Office versions now disable all ActiveX by default to reduce attack surface .
Enabling ActiveX is only advisable if you have complete trust in the form’s source and there are no alternative options, such as converting it to a non-ActiveX-based custom form. Otherwise, malicious forms could potentially execute code through hidden or untrusted ActiveX controls.
Maybe a different option could be to:
- In Outlook, go to File > Options > Trust Center > Trust Center Settings> ActiveX Settings
- Choose Prompt me before enabling all controls with minimal restrictions.
- Save and re-open Outlook
