How i can solve (0x803fa067) im using a macbook pro 2017 with intel CPU, im trying get answer but nothing yet!!!
santiago rivas caicedo 25 Reputation points
2025-07-21T23:04:38.6533333+00:00
Please let me know how i can solve it!! ๐Ÿ™Œโค๐Ÿ˜Š
I have a Macbook Pro 2017 wth Intel 4k series with Win 10 Home in Boot Camp, i apresiate the answers.
Windows for home | Windows 10 | Licensing and activation
Jeronimo Fuerte 45,750 Reputation points Independent Advisor
2025-07-22T00:31:22.9533333+00:00
Hi! According to the error message you are seeing, means Windows canโ€™t activate because it doesnโ€™t see a valid product key or digital license.
If your key is used on another device, you must remove it from that device or buy a new key.
If you have an old PC you no longer use, delete Windows from it, then try activating again.
1 additional answer
  1. Sumit Kumar 0 Reputation points
    2026-09-03T09:56:13.7766667+00:00
    window is not activate
