can fonts be added to my android to faithfully playback a prez on android?
2025-07-12T07:47:05+00:00
Can some of my fancy purchased fonts be installed onto an android tablet to make my pptx prez play back faithfully and without substitute some of my fonts
Is there a workaround to make this happen?
Yes, i know that fonts can be packed and saved with a presentation but what about restricted fonts (apart from replacing them)?
Thank you
Microsoft 365 and Office | PowerPoint | Other | Android
    2025-07-12T09:59:23+00:00
    Hi Mr, I'm Kelvin an Independent Adviser. I know how frustrating it is. Allow me to assist.
    Unfortunately, because of Android restrictions and licensing limitations, adding custom fonts is not supported. You can export the presentation as a PDF or save key slides as images to keep the design and avoid font problems.
    Thank you for your kindness and understanding.
    2025-07-12T10:44:41+00:00
    I require to view and display the presentation with all the effects and motion paths - converting to a pdf does not help my cause
    Thanks anyways
    2025-07-12T11:08:24+00:00
    Thanks for the follow up update Mr, I understand you need a full animation support. However, Android has limitations and does not support embedded orr restricted fonts in PowePoint. So, I recommed to use a PowerPoint or a Windows device online using a supported browser.
