Minimum width of to-do window in "full view" is too wide
2025-05-28T08:00:29+00:00
For some reason, when in "keep on top" mode, I am allowed to make the window very narrow (about 100px), but when in "full view" i.e. normal window I cannot reduce the width anything like as much, despite the fact that it does change its layout responsively to a single column layout before reaching its minimum width.
My intention is to use ToDo as a permanent side-bar on one of my screens so I can stay focused on my priorities, but in full view it occupies far more horizontal space than necessary.
Why not just use "keep on top" view and make it narrow? Well, for some unfathomable reason, the keep on top view doesn't allow you to have a vertical height more than approx 1/2 the screen height, so that wastes a large rectangle of screen space below it (see this bug report: https://answers.microsoft.com/en-us/msoffice/forum/all/microsoft-to-do-resize-the-window-in-keep-on-top/45444bda-bc80-4cad-8ceb-250e9de1e34f )
Microsoft 365 and Office | Microsoft To Do | For education
    2025-05-28T11:46:43+00:00
    Hi SamPrin
    Thank you for reaching out and sharing your experience with Microsoft Community. I understand your concern regarding the window size limitations in "Keep on Top" mode and "Full View" mode. Specifically, you’ve noted that in "Keep on Top" mode, the window can be resized to a very narrow width (about 100px), but it restricts the vertical height to approximately half the screen. In contrast, "Full View" mode doesn’t allow the window to be resized as narrowly, despite its responsive single-column layout, which impacts your ability to use To Do as a permanent sidebar on your screen.
    It appears to be part of the default design of Microsoft To Do. I kindly encourage you to submit your feedback directly to Microsoft through Microsoft Feedback Portal. Your input is valuable and can help the development team understand user needs and consider adjustments in future updates.
    Here’s how you can provide feedback:
    1. Visit the Microsoft Feedback Portal:
    1. Upvote & collaborate:
    • Check existing suggestions and upvote similar ones. The more votes an idea gets, the higher its priority!
    Please let me know if you need any additional assistance— I am here to help!
    Best regards,
    Doris V - MSFT | Microsoft Community Support Specialist
