Backup issue
2025-05-31T11:45:04+00:00
I use onedrive to store a backup of my notebooks from Goodnotes 6. This app provides me a continuous back up of the data so I deleted the application and all its data trusting my backup on your cloud service. When I downloaded the app again it showed me an outdated backup and when I look through the onedrive application the backup I was looking for was gone.
How can I be able to access this back up?
Microsoft 365 and Office | OneDrive | For education | iOS
    2025-06-01T15:23:26+00:00
    Hello Marco,
    Thanks for posting in the Microsoft Community.
    1. I recommend signing in through the OneDrive web portal using the following link: Persoonlijke cloudopslag – Microsoft OneDrive
    2. Unlink and Reconnect Your Account
    • Click the OneDrive icon in the taskbar.
    • Go to Settings > Account > Unlink this PC.
    • Restart your computer and sign in again.
    1. Check for Sync Issues
    After reinstalling the app, OneDrive may not have synced properly:
    • Right-click the OneDrive icon in your system tray.
    • Go to Settings > Account and ensure your folders are selected for sync.
    • If needed, click Unlink this PC, then sign in again and reselect folders.
    3. Reset OneDrive
    If the app is stuck or showing outdated data:
    • Press Win + R, type: %localappdata%\Microsoft\OneDrive\onedrive.exe /reset
    • Press Enter. This will reset the app without deleting your files.
    • Restart OneDrive from the Start menu.
    Best wishes,
    Maryam | Microsoft Community Support
