Problem with Phonetic Keyboard
2025-07-11T03:16:20+00:00
For past 2 days, Phonetic (Hindi) keyboard is giving problems. When I try to type a word, starting with some characters (like t, d, b etc.), it is not typing/converting beyond few characters.
Tried after rebooting the system 3-4 times. Removed Hindi language and re-installed also. Re-installed Hindi Phonetic keyboard as well. Nothing worked.
I have been a user of Phonetic Keyboard (Hindi) for many years and never faced such issue.
Please help.
2025-07-11T09:42:44+00:00
Thanks for the update, Anurag.
Since the issue happens in all apps and Hindi Traditional works fine, it confirms the problem is with the Hindi Phonetic keyboard itself, likely due to a recent Windows update. You've done the right steps by updating Windows and sending feedback through the Feedback Hub.
While waiting for Microsoft to fix it in a future update, you can use Google Input Tools (online) as a temporary option for Hindi typing.
Take care and all the best,
Arlene D.
41 additional answers
    2025-07-18T06:36:39+00:00
    I have same problem with Telugu Phonetic Keyboard please
    2025-07-18T09:32:10+00:00
    I uninstalled the last security update. Now its working fine. Hope there is a fix soon.
    2025-07-18T13:03:58+00:00
    I am also having the same issue with Tamil phonetic keyboard in few days. I tried all possible ways. but issue is same.
    2025-07-18T15:38:29+00:00
    You have to revert to the previous updation, then it’ll work properly.
