A family of Microsoft word processing software products for creating web, email, and print documents.
There have been problems recently with some shortcuts being changed, especially those shortcuts that are different in different language versions of Word. The problem is being investigated by Microsoft.
You should be able to change the shortcut manually, though. Ensure that you save the modification to the Normal template, so that it applies to all documents in Word.
