Excel Error "Excel ran out of resources while attempting to calculate" upon calculation interruption
2025-02-06T22:04:26+00:00
I am using Excel, latest version for Mac, 16.93.1 (25011917), and following a recent update either to 16.93 or 16.93.1 I have systematically an error message if I interrupt a calculation : "Excel ran out of resources while attempting to calculate one or more formulas. As a result, these formulas cannot be evaluated." after this error I must always quit excel and restart which is very annoying. Anyone having the same issue ?
Microsoft 365 and Office | Excel | For business | MacOS
    2025-02-07T17:37:03+00:00
    This can be a common problem, especially with large or complex spreadsheets. Simplify complex formulas or break them down into smaller parts. This can help reduce the amount of resources needed for calculations.
    Could you share a test file? Then I can help you optimize the formulas on that file.
    For sharing file, you may upload it to OneDrive or any other cloud drive and then post the link here.  *Please make sure you have removed any sensitive or private information in the sample file before uploading.
    2025-02-10T10:13:36+00:00
    Hi Snow, thanks for your reply. Unfortunately I would need to take some time to remove sensitive information from my files.
    That said, my concern is that this happens on many files, and I never (as far as I remember) had such an issue previously, I mean before that update to 16.93.1 or 16.93 (not sure which of the 2 updates introduced the issue). Previously if I interrupted a calculation it would simply stop calculating... I didn't need to completely exit Excel and restart it... never. Now, I almost systematically get this message "Excel ran out of resources while attempting to calculate..." and then I need to close all Excel workbooks and exit Excel if I interrupt a calculation. This is such a systematic issue that I assume this is probably happening with other users. Don't you got other users reporting that issue after those updates ?
    2025-02-12T03:44:28+00:00
    Hi Aaron, thank you for posting this. I am in the same boat. I have a complex spreadsheet that has worked for years. It contains power query tables and most formulas use dynamic ranges. We are running it on a windows virtual server with lots of CPU and memory capacity. Using Office 365 E by the way.
    It worked perfectly until the January 31st 2025 office update; I'm not sure of the version number of this update. I have never seen this error before. I had daily backups of this same workbook going back months and they are also demonstrating this same error. Which suggests it is not the workbook but an Excel bug or limitation change related to the update.
    On Tuesday of last week, I pushed through an update on our operating system and the workbook appeared to work for a few days but once again I'm getting this error.
    At this point, I am going to get our IT guys to roll back our excel version to pre January 31. Any permanent solution would be welcomed.
    2025-02-12T05:27:23+00:00
    Another discovery, I just learned there was another update released today February 11 2025. The timing of these last two updates and this error appearing twice immediately following each is suspect.
    https://learn.microsoft.com/en-us/officeupdates/update-history-microsoft365-apps-by-date
    2025-02-12T13:42:45+00:00
    I believe I made some progress for anyone reading this.
    In order to debug this problem further - I had stripped down all the formulas in workbook on the most computationally complex worksheets.
    FYI: An easy way to do this is just to search and replace all "=" with an unusual string, I use "meow". I then add back formulas one by one until the error is triggered.
    The problem appears to have triggered at Lambda functions. I use the ByRow function a number of times.
    =IF($E25#="UN",0,IF(GO$21="OFF",1,BYROW(EW25#:EZ25#,LAMBDA(x,IF(ISERROR(PRODUCT(x)),0,PRODUCT(x))))))
    E25# contains various text string codes. If the value is "UN" it just returns a 0
    EW25# to EZ25# are small numbers between (0 and 1)
    The function above, that worked great for years, seems now be triggering the insufficient resources state.
    ----------------------------------------- Yes that seems to be the trigger
    I tested it by creating four spillable sequences as shown below (Columns FA, FB, FC, and FD) They are 650 rows long and the formula in FE triggers the issues.
    ****** This is clearly a Microsoft update error, a formula that worked for three years shouldn't be triggering this. Especially with something as basic as multipying integers in for only 650 rows.
    ![](https://learn-attachment.microsoft.com/api/attachments/cf4713b8-5035-4dd0-81eb-902a17cd2e38?platform=QnA
