Can people keep using Microsoft Publisher unsupported after the end of support date in October 2026?
2025-01-24T19:39:30+00:00
Hello, Microsoft announced that Publisher will not be supported after 2026, but the announcement was vague so I wanted to clear up a few things:
  1. Will Microsoft Publisher still be available to use (albeit unsupported) after October 2026 or will it be removed from computers that have them?
  2. If it is removed, does this only apply to Microsoft 365 subscriptions or will Office 2021 lifetime standalones also have Publisher removed?
  3. What if you want to continue using Publisher? Much of my work revolves around using Publisher. Is there any way to keep it after Oct. 2026?
Original End of Support message: Microsoft Publisher will no longer be supported after October 2026 - Microsoft Support
Thanks in advance!
Microsoft 365 and Office | Publisher | Other
Diane Poremsky MVP 17,526 Reputation points MVP Volunteer Moderator
2025-03-31T12:02:32+00:00
  1. Publisher is being removed from the Microsoft 365 subscription in October 2026. As of March 2025, the plan is to remove it from computers that have the subscription. (This may change.)
  2. It only applies to the Microsoft 365 subscription. Office 2021 and older are not affected. Note: Publisher is not in Office 2024.
  3. If you have Office 2021 or older, Publisher will not be removed. Microsoft is considering options for people who are using Publisher.
Any changes to the policy will be updated in this article:
102 additional answers
    2025-02-23T03:53:25+00:00
    Tracy --
    I have the same question about using Publisher after 2026, but your answer is muddled and confusing.
    You write:
    "Publisher will not be available after 2026, and even if the application is installed, it will not be accessible...Because publisher has stopped all services, unfortunately it will not be able to be used."
    But the link from OP (from support.microsoft.com) said in its FAQ section: "If you have the Perpetual version of Publisher, you will still be able to access and edit your files." and "...if you have the Perpetual version of Publisher, although support will end, you will still be able to install and use the app beyond this date."
    So:
    1. the perpetual version of Publisher WILL WORK indefinitely, beyond 2026?
    2. how can I confirm that I have the perpetual version? I'm using Office 2019 with a lifetime license. Is this the same as "perpetual version"?
    2025-02-26T01:15:52+00:00
    It isn't available for download now and it is Feb. 2025! I need the download and I pay for Office 365!
  3. Stefan Blom 352K Reputation points MVP Volunteer Moderator
    2025-02-26T12:43:48+00:00
    If you have Office 2021 or some other, older perpetual license, you should be able to run Publisher after 2026.
    Note that Publisher is not included in Office 2024 (the most recent perpetual license, released in 2024).
    2025-03-04T23:51:22+00:00
    Thanks, Stefan : )
