Powerpoint slides disappeared after not saving a copy
2024-12-20T13:43:14+00:00
I have done some powerpoint slides in June this year for a diary for my holiday. When I was finished with all the slides on the last day, I checked the number of slides and it said ‘93’ slides. But now in December when I checked they only saved until 50-60 slides, so the other 40 slides were gone. It said last modified on 10 June, but that was halfway through my holiday. On 10 June 2024, I remember that the presentation were accidentally deleted by me but I managed to recover it. A few days ago when I checked that presentation, it had all the 93 slides and it said that ‘my changes can’t be saved and I have to save a copy’ but I did not because I thought that something will happen. But now, the ‘save a copy’ tab is gone. Please help!
Microsoft 365 and Office | PowerPoint | For home | iOS
    2024-12-26T12:18:09+00:00
    Hello, EBENEZER YONG
    Welcome to the Microsoft community.
    I realized that you have encountered a problem with recovering an PowerPoint file. I understand how difficult it is to lose important data.
    I notice that you posted in iPhone or iPad section. I would like to know where this file is stored?
    1 -> If it's stored in OneDrive, you can try:
    • Search for your files in the OneDrive online. If you can find the file, right-click it and select "Version history". See if an earlier version has all 93 slides and recover it. Image
    • Look in the Recycle Bin. Visit OneDrive online. On the left side of this page, select Recycle Bin. If you find the PowerPoint file, select it and choose Restore.
    • If you're a Microsoft 365 subscriber, you can use OneDrive's file recovery feature to undo all the actions you've taken on photos and folders in the last 30 days. For step-by-step instructions, see: Restore your OneDrive - Microsoft Support
    • If the above steps don't work, I sincerely recommend contacting OneDrive email support. The support agent may help you recover the file. To contact: Log in OneDrive online, then click this link: Email OneDrive Support. Or you can click the feedback button in the upper-right corner. Image
    2 -> If it is stored locally on the iPad or iPhone device, you can try searching in the device and see if there is temporary file containing the contents of the slide.
    3 -> If you have saved them in a third-party cloud storage such as iCloud, I suggest you look for the corresponding file recovery method of the software.
    4 -> If the above methods don't help you recover your files, I sincerely suggest you consider using third-party data recovery software or seek the help of a third-party data recovery company.
    I can only imagine how difficult this must be for you. I sincerely hope that you will have the chance to recover the important data. Thank you for your understanding and cooperation.
    Best wishes,
    Lucia Wu - MSFT | Microsoft Community Support Specialist
