I am still having probems with the STOCKHISTORY function, but not in terms of producing ERRORs I am no longer getting "Excel ran out of resources" that others have mentioned either. I have posted the following under a new thread per your suggestion, but wanted to also post it here FWIW to others in the thread.
My new problem is that STOCKHISTORY is returning incorrect prices for random tickers. And the specific ticker(s) for which it happens is/are different every time I re-open the file containing the errors. I've tried overwriting the incorrect cells with the same formula from a different cell that is correct and re-calcing, but it just reproduces the same incorrect result for the erroneous ticker in question. I have also been re-opening the file, which usually results in the previously erroneous results being corrected, but then an erroneous results shows up for a different ticker. I've tried this both with automatic re-calc and manual re-calc, but it is rarely and very inconconsistently correcting the problem for ALL tickers at one time in either case.
Though a less widespread problem than before in terms of the number of tickers affected at one time, this is actually worse in a sense since it is not producing error messages. It is producing results that are incorrect and those erroneous results are not readily aparent without digging to find them. I only discovered that it was happening because some higher level calculations using multiple ticker results were not making sense. This all but renders my analyses useless and takes up a lot of time to have to go in ticker by ticker to identify the erroneous results and account for them accordingly in my decision-making because the occurence of the problem is seemingly completely random.
Please make this a very high priority to correct.
Thank you.
