A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
And I waited until they did a normal update instead of the Preview beta test version. Should have waited a bit longer.
Hi Team,
I spent over 2 hours troubleshooting this issue with an advocate in Office support (7*********0). He worked very hard to understand and resolve the issue.
We tried numerous resets: the network, uninstalling and reinstalling office, updating office, powering down, and restarting the computer. Nothing helped.
The issue occurs in approximately 20% of the values for a list of stocks and one date. It occurs in a similar percentage of dates for a single stock.
Ultimately we discovered that creating a new spreadsheet and typing or pasting the formula into an empty cell will not result in the #CONNECT! error. But this does not work in previously created spreadsheets.
Please check on this as soon as possible. This is a critical function for applying Excel to stock research.
Thank you for the troubleshooting idea. I tried another version of Excel, on another system, the 2407 version. I run the updated 2408 version on my personal account. Both versions have the STOCKHISTORY() #CONNECT! issue.
Good morning
I think this has something to do with the data source since in my case, the #CONNECT error only shows up in certain stocks.
(1) This morning I opened a new spreadsheet with the same fields of the table that has the errors and started entering some stocks that I am planning on trading this week. So far all have displayed the correct information. Then I entered a stock that has the #CONNECT problem in the other sheet and it comes back with the error. So this is only on selected stocks.
(2) I did not count the number of records that showed the problem yesterday so I cannot really verify this, but it seems to me that there are less #CONNECT errors on the sheet.
(3) Yesterday I was constantly getting an error label, you know, the label that appears just below the menu, an today it has not appeared. So I guess the issue is slowly being resolved.
(4) This is not the first time I get strange behavior after an upgrade, the other day I had one with a need to add memory to a partition, and the solution was quite technical, so it would be nice if MS would do more testing before launching upgrades.
My two cents.
Mario
I have had the same issue since August 16th or 17th (Not sure exactly when I first saw the problem.) Also have spent lots of time since then trying to chase down the cause/solution without success.
I am finding that the frequency and specifics, (stock, date(s)), of the erroneous cells change when I refresh my workbook. They never all work, and at least a few work each refresh, just not the same ones every time.
My StockHistory functions rely on Dates in different cells. And when I change the dates the #Connection errors will go away (I actually change a cell that feeds into the date that changes the date).
