MS Project calculation help
2024-11-29T09:14:04+00:00
I'm currently doing a MS Project Beginners to Advance course on YouTube.
My issue is, we are doing a relatively simple calculation. The calculation is to create Red, Amber, Green flags for variances in costs.
I am using their example sheets, therefore should not be any issues relating to missing fields - at the very least.
I have copied their calculation verbatim per the course and it does not work.
The calculation is:
IIf([Cost Variance]>0, "X", "G")
What it is saying is:
if the cost variance is greater than 0 - if true, output an "X" for positive values.
For the G - if false, the cost variance is negative then output a "G".
I get the below error pop up every time and don't understand why?
"The formula contains a syntax error or contains a reference to an unrecognized field or function name."
Microsoft 365 and Office | Project | For home | Other
2024-11-29T09:41:43+00:00
Well, that works for me in a text field. Is your formula in a custom text field?
In your country version of MSP maybe the quotes or comma separators should be other characters. Try single quotes.
1 additional answer
    2024-11-29T10:46:52+00:00
    Hi Trevor,
    Thank you.
    I changed the comma separator - to works now.
    Much appreciated.
