A family of Microsoft word processing software products for creating web, email, and print documents.
Darn! It should (finally) resolve after that. Maybe you can nudge.
Jenn
Greetings,
Since the last update (currently running MS Word Version 2408 (Build 17928.20156), some of the comments that I make in Word documents do not appear in contextual view, even though they appear in list view. I am not able to click on them in the text and have the comment appear in contextual view. After I make some comments, they disappear and are only available in list view. I am working on an important paper for the top medical journal in the world, and it is debilitating as an editor to not be able to make comments. This document is shared with 20 people. It has also happened in another document that I am working on for another client (in this document, it happened before the document was shared).
I called support. They cannot help and claim that it is not a Microsoft issue. I have copied and pasted the text with the broken comments into a new document and the problem still occurs. Saved the document to my PC (instead of OneDrive) and the problem still occurs. I have accessed the document on another computer and the problem still occurs.
I am beyond frustrated. My colleagues, global leaders in their fields, are mainly older and are technologically challenged. They will not understand if I tell them to look at the comments in list view instead of contextual view. Essential comments will be missed. I just need it to work properly. I am beyond frustrated.
Any advice is most appreciated!
Jenn
There is probably an additional bug fix regarding Track Changes and Comments pending for your Office installation.
See the version history at https://learn.microsoft.com/en-us/officeupdates/current-channel.
Good luck!
