A family of Microsoft word processing software products for creating web, email, and print documents.
Microsoft releases updates in stages to different update "channels" (i.e., Current, Monthly Enterprise, Semi-annual Enterprise). They release updates first to the Current channel, then to Monthly, then to Semi-annual.
To check your channel and version and/or to run a manual update:
- Open Word
- Click File, and in the very bottom left, click Account (may have to click More... depending on your screen size)
- On the right side next to the About Word button, look for your version and channel.
- If you're on Current Channel with Version 2502 (Build 18526.20144), you're good to go!
- If you're on Current Channel with Version 2501 or earlier, you need an update. a) Click the Update Options button at the top of the section on the right side b) Click Update Now to check for and apply updates.
If you're not on the Current Channel, the bug fix will likely be included in the other channels in the next month or two. Keep in mind, if your device is company-managed, you may have not control over your channel or when updates are applied. You can reach out to your service desk for assistance.
