Some comments not appearing in contextual view, but appear in list view.
2024-09-21T00:50:47+00:00
Greetings,
Since the last update (currently running MS Word Version 2408 (Build 17928.20156), some of the comments that I make in Word documents do not appear in contextual view, even though they appear in list view. I am not able to click on them in the text and have the comment appear in contextual view. After I make some comments, they disappear and are only available in list view. I am working on an important paper for the top medical journal in the world, and it is debilitating as an editor to not be able to make comments. This document is shared with 20 people. It has also happened in another document that I am working on for another client (in this document, it happened before the document was shared).
I called support. They cannot help and claim that it is not a Microsoft issue. I have copied and pasted the text with the broken comments into a new document and the problem still occurs. Saved the document to my PC (instead of OneDrive) and the problem still occurs. I have accessed the document on another computer and the problem still occurs.
I am beyond frustrated. My colleagues, global leaders in their fields, are mainly older and are technologically challenged. They will not understand if I tell them to look at the comments in list view instead of contextual view. Essential comments will be missed. I just need it to work properly. I am beyond frustrated.
Any advice is most appreciated!
Microsoft 365 and Office | Word | For business | Windows
  1. Stefan Blom 352K Reputation points MVP Volunteer Moderator
    2025-03-01T18:33:29+00:00
    James,
    What you describe is the issue which is still being investigated, I believe.
    Make sure to send feedback to Microsoft, using the feedback facility in your version of the program. You may also want to post feedback in the portal at https://feedbackportal.microsoft.com/feedback/forum/fb6d67e3-301c-ec11-b6e7-0022481f8472.
    2025-03-07T15:46:33+00:00
    There's a potential fix in the Current Channel build that was released on March 5, 2025. See the fourth bullet point under the resolved issues for Word. (also pasted below)
    https://learn.microsoft.com/en-us/officeupdates/current-channel#version-2502-march-05
    I installed this build on a test machine, and all comments are now showing correctly in Contextual View.
    Version 2502: March 05
    Version 2502 (Build 18526.20144)
    Resolved issues
    Word
    • Resolved an issue when using Track Changes where comments may not be visible in contextual view until changes are accepted or rejected.
    2025-03-08T19:22:01+00:00
    Thank you for flagging this! Looking forward to updating (for once). I will report back.
    2025-03-08T23:21:42+00:00
    Thanks so much for sharing this, Jason. Begging your patience (I'm not especially tech savvy), but does this mean that the next time I'm prompted to update MS365 this potential fix will be included in that update? I don't know what a current channel build is. Thanks again for the—hopefully!—good news. Fingers crossed!
    2025-03-09T12:57:29+00:00
    Wow I can't believe it, Microsoft actually finally came up with a fix for this! Thanks so much for informing the group here.
    Let's hope this resolves the comments not appearing in Contextual view once and for all. I echo another user here who ask, will this fix be implemented when we're prompted to update Windows in the system? Also, how do we know if the patch has been implemented into the Word program? Is there something we need to do? Appreciate any advise!
    Thanks!
