A family of Microsoft spreadsheet software with tools for analyzing, charting, and communicating data.
June 2025 and I'm having the copying error. I uninstalled Logi Options+ that was installed a week ago and no more error message. So annoying.
There have been many posts on how to fix the message Clipboard Error. We couldn't copy the content to the clipboard because its in use by another application.
I tried many of the suggestions:
None worked. I have a test macro that works for several minutes and does many copy/paste, graphics, formatting, etc. It would display the clipboard error at least once every 2 or 3 executions, and often every execution. I used it to test all the posted cures.
What I finally realized is that the application that was using the clipboard and causing the error was Excel itself. Excel was basically not able to keep up with the command to clear the clipboard.
The cure then became simple. Slow excel down by using the statement "DoEvents" right after I issued the command "Application.CutCopyMode = False". And to put the Application.CutCopyMode = False after I was finished with any copy that I did and right before any workbook close command. I've run my macro 10 times and no clipboard error message appears.
Please give it a try.
This fixed my issue. I had already tried the "Application.CutCopyMode = False" after every Paste or after any Cut that wasn't going to be Pasted, but still would get the Clipboard error every so often in a macro that does A LOT of work. Adding the DoEvents fixed it. And I do use Logitech Options, as do others that use my Excel tools.
For those where the DoEvents isn't enough, maybe add a loop and check the CutCopyMode. If it's not False (it can be False, xlCopy, or xlCut), keep doing a DoEvent (though definitely set a Timeout of some type if you do this). If you go that far, a subroutine is really the only option, so here it is:
Public Sub ClearClipboardIssue(Optional dMaxTime As Double = 2)
Dim dStart As Double, dTimer As Double
dStart = Timer
Do
DoEvents
If Application.CutCopyMode = False Then Exit Do
dTimer = Timer
If dTimer < dStart Then dTimer = dTimer + 86400 ' Watch for WRAP at MIDNIGHT!
If dTimer - dStart >= dMaxTime Then Exit Do ' Give up and accept the warning. It's
' annoying, but doesn't break anything!
Loop
End Sub
For me, it was Slac that was holding the copy functionality up.
What's disturbing is that I hardly ever use Slac.
Now that program gets to live in the bit bucket. :-)
Thank you! Like many others on this thread, I was losing my mind trying to figure out the source of this constant error. I disabled Logi Options+ and it was immediately fixed. It's a shame that almost a year after this post the software has not been fixed to correct this issue.
