Processes in Microsoft 365 for setting up Office apps, redeeming product keys, and activating licenses.
Please see the below.
Just realized that MS Lists only allows 1 column for attachments (though allowing multiple attachments). The problem is, I was trying to create multiple columns so the attachments can be added by category.
Since I can't categorize multiple columns, I need to be able to separate the attachments into categorized folders once they are uploaded but I want to do this automatically.
How do I use Power Automate to grab the attachments and place each file in separate SharePoint folders? Thanks!
Lissa
Dear Lissa,
Thanks for your updates.
The file name and the file extension seem to be extracted correctly in your environment. You can just combine them when creating new files.
Thank you for your time and effort.
Sincerely
Cliff | Microsoft Community Moderator
Thank you. Please explain what is meant by, "You can just combine them when creating new files."
Dear Lissa,
You can just combine the name and the extension in the Name part in the Create File action in your flow.
Sincerely
