OneNote fingerprint unlock is not working
2024-07-22T11:08:18+00:00
When setting up a protected section on Onenote on my samsung fold6 it I enable the box that says use fingerprint next time but when I go to unlock it again it asks for the password again with the use fingerprint box still enabled. It never lets me use my fingerprint to unlock the sections. Anyone know a fix for this?
Microsoft 365 and Office | OneNote | Other | Android
    2024-08-04T14:45:14+00:00
    Worked for me as well! GREAT FIND!!
    2024-08-04T15:04:11+00:00
    Can you link which APK you used please? as the ones I keep trying error out. Thank you for finding a solution
    2024-08-04T15:17:33+00:00
    com.microsoft.office.onenote_16.0.17231.20016-1805865907_minAPI28(arm64-v8a)(nodpi)_apkmirror.com.apk
    It's the version I used. Jan 2024 apk. Then update via play store. You might have to enable dev options to allow side loading apps from external locations.
    2024-08-04T15:23:15+00:00
    Nevermind got the apk working thank you so much it all works now
    2024-08-06T01:13:45+00:00
    Hi! Oleksandr Dudarenk,
    Thank you for your response!
    We have had a lot of feedback from users here with the same issue, and we apologize for the inconvenience this issue has caused many users. Thanks to our enthusiastic user @LKR307 for finding a version that works for many users. This issue may be a widespread problem, but at this time our testing has not been able to reproduce the issue, we recommend that users provide feedback to the development team, please click on the link: Ideas · Community (microsoft.com), where specialized developers will pay attention and comment on your feedback. After sending your feedback, you can share the feedback link in this forum so that other users with similar problems, including me, can vote for your feedback and the more votes you get, the more likely you are to get attention from the development team. Thank you for your understanding and support. Microsoft takes user feedback very seriously and if you have any ideas or suggestions for the future, you can use the feedback channels mentioned above. Best Regards Eddy | Microsoft Community Support Specialist
