When will the Check Box feature in Excel be available
2023-11-09T13:53:26+00:00
There is a new Excel feature on the insert tab of the ribbon that allows users to put a Check Box on spreadsheets without programming. When will that be included in my updates?
thank you
Microsoft 365 and Office | Excel | Other | Windows
    2024-01-17T18:01:21+00:00
    thank you for replying and for the comment about how functional the checkbox is altogether.
    2024-02-16T15:08:19+00:00
    I'm currently on v2401. The boolean checkbox is not in this version yet. I'm waiting for this feature specifically because it opens an entire world of logic for lookups, validation, and easy management of sheets. Google sheets had it years ago. It's bizarre that it's not in excel yet. It's literally just a visual switch for a boolean data type.
    2024-02-16T15:20:22+00:00
    Thanks. If it makes you feel better, I don't have it either. :)
    2024-02-16T15:28:47+00:00
    Thanks for the response
    2024-02-16T16:58:36+00:00
    We are governed by our IT department with group policies. I cannot join the insider program🙄
