OneNote Web Clipper will not sign in
2023-07-25T10:30:47+00:00
OneNote Web Clipper extension on Microsoft Edge stopped working after I cleared browser caches with CC Cleaner.
It worked for a long time, but now it completely stopped working. It asks me to sign in, so I get this:
After I click on Sign in with a Microsoft Account, a window appears but there is no sign in flow, it does nothing but shows me a page "Get OneNote Web Clipper".
I'm unable to sign in, it appears that the login flow is broken. I'm already signed in to my personal Microsoft account throughout my apps and in my browser. I can access the OneNote application and https://onenote.com/ site without issues.
Please help if there is another workaround to mitigate this issue. If there's no fix I can't use the Web Clipper extension anymore.
    2023-08-03T22:38:38+00:00
    Hello all,
    I found a workaround: Quit webclipper and use the integrated funtionality of Web Capture of Edge. You can capture everything how you want it and just paste it in onenote. Onenote finds everytext even in photos. Additionally if you use the web capture the content you capture is allso editable in onenote. Try it, it works like a charm. As a solution is a little cumbersome but works good enough for me to ditch evernote!
    Let me know what you think!
    Regards
    Panos
    2023-08-03T22:56:35+00:00
    Thank you for this workaround. It’s information I can use and it is a suitable solution until Webclipper gets fixed.
    2023-08-03T23:13:09+00:00
    Yes, thank you very much Panagiotis Rafailidis1!! The Web Select option is similar to the option I typically use in Clipper. It leaves everything as text, not images (which is why I don't like the Print to OneNote workaround), but gets rid of all of the advertisements in the middle of the page.
    So - since everyone is pitching in to help out here, I received multiple advertisement emails from MS saying that you can send Edge Collections directly to OneNote, but I can't find the option or how to do it anywhere. Does anyone know how to do this?
    2023-08-04T05:45:59+00:00
    A work around yes, but it is less than satisfactory (for my workflow).
    I just hope that the inconvenience of not being able to log into OneNote web clipper is just part of bigger plan and the compensation will be an even better tool.
    Not holding my breath!
    2023-08-04T06:17:01+00:00
    I too have been looking for the option to send collections to OneNote but can't find it anywhere.
    The best method I have come up with is to "Copy Items to Clipboard" (an option in the "More options menu") and paste into an email to myself and then send to OneNote from Outlook. Not convenient but works.
    I hope this helps
